Does anyone know how to make ProjectWise Automatically "Purge Local Copy" without having to do it every time I am finished with a document? Is this possible?
Did you ever get an answer on this? This is a user setting and not a programming issue.PW allows the administrator to define if a copy is left on free and/or check-in. It can also be specified if the local recycle bin is used.
