I would like to populate information from ProjectWise into an OpenRoads Report. The data is already created in fields of the PW project folder.
I have very little programming training, but I think this will work if I can point the report in the right direction. I asked this in another Forum, but I thought you folks might be able to help.
Thanks, Dan
no API needed for this. Are you asking how to include that information with Bentley Reports? You probably need to contact support for help with this one.
Hi Dan,
Use the raw XML main report to see what data is available for you to report. You many find it will only show you the local PW storage folder unfortunately.
You may get more info in the Bentley Civil (Openroads) forum.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
