How to retrieve document path using Projectwise web services gateway?
Good question. The best way I have found is to use iteration.
Keep retrieving the parent project instance and build the path from the Name attribute until the parentGUID attribute is no longer returned.
Answer Verified By: Oto
Seems lot of iteratons an requests for such simple task. Was expecting to get URL/URN similar as PW explorer does.
I am new with Projectwise Web and was wondering if you have been able to find a solution for this issue. We have a high amount of isers requesting this functionality and, after two years of tour question, I don't know which technical reason block a solution for that
Not really the PW web services are as easy as Chinese alphabet and documentation is horrible could not find what I needed.
Schemas class instances etc. totally different approach as it is in GUI:
ctdot-ws.projectwiseonline.com/.../index.html
