Sending initial handshake requests for file upload through the Web Services Gateway, reguests are rejected with status code 413 ( Request Entity To Large) for file size above 30 MB
How to increase this limit? With PW Explorer it seems to be no problem adding files far above this size..
Found that Wsg.Files.UploadMaxFileSizeKB was set to 30740 in the web.config file located at %SystemDrive%\inetpub\wwwroot increased this limit. Then had to make sure the initial number of chunks used to transfer the file is large enough so that each body part always is less that the initial limit..( seems like another limit for each part set somewhere..)
Answer Verified By: Reidun Hansen
I am facing same issue. when I set chunk size to 10MB , it fail to upload file to projectwise abd setting chunk size = 1MB , uploading file successfully.
what is default max chunk size ? where do we set this max chunk size?
