I am trying to connect via the api to a Projectwise Server but get the error: Error 58064 "Cannot login to the datasourceInvalid user name and password combination."
And also this in the pw.log:
https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/33057/connection-client-fails-to-sign-in
The username and password is set in the adminstrator as firstinitiallastname and the password which is what i am passing in. They use a cloud server with gateway servers on site. I am connecting to the cloud server. I am able to list the datasources on the server through the api.
1- Do you know what the username/password combination issue might be?
2- Optimally, they would rather connect to the local gateway server. This doesn't work at all through the api testing I tried. Is this possible?
The API uses the local install of ProjectWise Explorer. Can you log in with Explorer to this datasource? If so consider the arguments you are passing. Are you using C++, C# or another language?
HI there. Thank you for replying. The Explorer is able to login but not via this C# code below. I wrote a little test app to test this.
ProjectWiseAPI.aaApi_Initialize(0); //AAMODULES_ALL ProjectWiseAPI.aaApi_InitializeModules(0); success = ProjectWiseAPI.aaApi_Login(0, dsName, user, pass, ""); //dsname = "HOSTNAME:DSNAME"
Here is how I do it.
//Interface Declaration
//dialog suppressed [DllImport(@"C:\Program Files\Bentley\ProjectWise\bin\dmscli.dll", EntryPoint = "aaApi_Login", CharSet = CharSet.Unicode)] public static extern bool aaApi_Login(int iDSType, string lptstrDataSource, string lpctstrUsername, string lpctstrPassword, string lpctstrSchema);
[DllImport(@"C:\Program Files\Bentley\ProjectWise\bin\dmscli.dll", EntryPoint = "aaApi_GetActiveDatasource", CharSet = CharSet.Unicode)] public static extern IntPtr aaApi_GetActiveDatasource();
//Use of interface
public static bool LogIn(string dsName) { string adminName = "MyUserName"; string pw = "MyPAssword";
aaApi_Initialize(1/*AAMODULE_EXPLORER*/); if (false == aaApi_Login(0, dsName.ToString(), adminName, pw, "")) { return (false); } if (IntPtr.Zero == (hDatasource = aaApi_GetActiveDatasource())) { return (false); } return (true);
You can set the data type of username and password to IntPtr and pass IntPtr.Zero if you want the login to use Single Sign-on.
