Using aaApi_DocumentSelectDlg (or similar dialog) it is possible to define what are the selectable file based on their extension.
Unless I am mistaken, it is not possible to do restrict documents of a specific extension using aaApi_SelectDocumentDlg, am I missing something obvious ?
Take a look at
Thanks for your reply Dan.
lpctstrFilter is the parameter I would need to use. Unfortunately unless I am mistaken it is not available for aaApi_SelectDocumentDlg.
I am wondering if exists a workaround with aaApi_SelectDocumentDlg to achieve what would lpctstrFilter would do with aaApi_DocumentSelectDlg.
If I recall correctly, you have to send in a pair. For example
"DWG|*.dwg"
This should fill in a drop down for the user to filter with.
