I need to access our developed web services from PW explorer.
I took example project from SDK library - docprop. I would like to have a possibility have a button which connect to my web services and get some information from there.
In C# i use code like this, but can't find how to make run it on C++ with MFC.
The other option is create command in C# for PW explorer, but i do not know how to this as well.
Darius
using (var client = new HttpClient(new HttpClientHandler { AutomaticDecompression = DecompressionMethods.GZip | DecompressionMethods.Deflate })) { client.BaseAddress = new Uri(sDomain); client.DefaultRequestHeaders.Authorization = new AuthenticationHeaderValue(scheme, pass); String sApiPath = "/master-tables"; HttpResponseMessage response = client.GetAsync(sApiPath).Result; response.EnsureSuccessStatusCode(); string result = response.Content.ReadAsStringAsync().Result; List<MasterTable> prTables = JsonConvert.DeserializeObject<List<MasterTable>>(result);
foreach (MasterTable t in prTables) { if (t.name.Contains(tablename) == true) { String sApiPathTr = "/master-tables/" + t.masterTableId + "/records"; HttpResponseMessage responseTr = client.GetAsync(sApiPathTr).Result; responseTr.EnsureSuccessStatusCode(); string resultTr = responseTr.Content.ReadAsStringAsync().Result; ReadMasterTableFromCodes = JsonConvert.DeserializeObject<List<TableRecord>>(resultTr); break; } } }
If I understand your question, you could create a C# Class Library (DLL) that calls your web service, but then make it available to unmanaged (C++) code. Take a look at Dave Brumbaugh solution to how to do this at https://www.nuget.org/packages/DllExporterNet4X64/ or this one https://www.nuget.org/packages/DllExporterNet4/ .
You might also want to take a look at Dave's Classes to access the ProjectWise APIs from C# at https://github.com/DaveBrumbaugh/MostOfDavesClasses-CSharp-Wrappers-For-ProjectWise
Hi Dan,
Thank you for quick answer and links.
My target is to have the same code in C++, what I have in c#.
I do not know is there in c++ MFC some functions which allows me get the same result what I have in C#.
I use MostOfDave clases in my C# projects and in really useful.
The question there is it possible create Menu in PW explorer using C# and MostOfDaveClases?
Best regards
Darius,
I don't know if there are MFC tools available to do what you want to do, but I suspect that you can do all that you want to do with C++, but you will have to do some "research" into the means to do so.
If you already have working C# code, and are more comfortable using C# and .NET, then there isn't really anything from stopping you to use both, you just need to have a way to invoke the C# code from PW Explorer, which of course is unmanaged code. Using the DllExporterNet4 tool makes this relatively easy to do.
If you want to call your C# code from a PW menu, trying this approach:
I have personally used this approach and the advantage is that you can keep the C++ code pretty minimal while taking advantage of the C#.NET development environment to implement whatever it is that you already know how to make work.
HTHs
Thank you for pointing me to the right direction, appreciate it.
Sorry, but I do not understand what I do wrong.
I have done simple C# dll and try follow by instruction.
Installed
Install-Package DllExporterNet4X64 -Version 1.0.0
There is my C# code.
using System;using System.Collections.Generic;using System.Linq;using System.Text;using System.Threading.Tasks;
namespace Exportteddll{ public class ExportedDll {
[DllExporterNet4X64.DllExport] static void test ( ) { System.Windows.Forms.MessageBox.Show("Hello"); } }
On post build I have added.
DllExporterNet4X64.exe $(TargetFileName)move $(TargetName).Exports$(TargetExt) $(TargetFileName)
on build I has got error message.
Severity Code Description Project File Line Suppression StateError The command "DllExporterNet4X64.exe Exportteddll.dllmove Exportteddll.Exports.dll Exportteddll.dll" exited with code 1. ExportedDll
Maybe you have some example. I need something for startup.
Thank you.
