PW SDK using C#
Hi all,
 I am trying to develop something through the API of ProjectWise. I have been using ProjectWise since 2016 and ucrrently using PW 10.00.02.265. I have been reading through SDK manual since more than 2 weeks but I had no clue. I have been reading the below that thread (https://communities.bentley.com/user/conversations#ConversationID=3def96ce-413d-4ac0-a799-46d0f2af79c6). which contains an image contining a sample login .
I feel that would be so helpful posting that sample which can save us a lot of time.
  • Here's the source for "Sample Login":
    using System;
    using System.Diagnostics;
    using System.Runtime.InteropServices;
    using System.Text;
    using System.Windows.Forms;
    namespace SampleLogin
        class ProgramSimpleLogin
            private static string sDatasourceName;
            private static string sUserName;
            private static string sPassword;
            private static void GetApplicationDefaultProperties()
                sDatasourceName = Properties.Settings.Default.DataSource.Trim();
                sUserName = Properties.Settings.Default.Username.Trim();
                sPassword = Properties.Settings.Default.Password.Trim();
            private static void GetUserSpecifiedValuesFromCommandLine(string[] args)
                bool ShowUsageMessage = false;
                for (var argIndex = 0; argIndex < args.Length; argIndex++)
                    if (args[argIndex].ToLower() == "-d")
                        sDatasourceName = args[++argIndex];
                    else if (args[argIndex].ToLower() == "-u")
                        sUserName = args[++argIndex];
                    else if (args[argIndex].ToLower() == "-p")
                        sPassword = args[++argIndex];
                    else if (args[argIndex].ToLower() == "-?")
                        ShowUsageMessage = true;
                    else
                        Console.WriteLine("[Error  ] Invalid command line argument '{0}'", args[argIndex]);
                if (ShowUsageMessage)
                    ShowUsageAndExit();
            public static void ShowPWError()
                Console.WriteLine("[{0}]\n{1}\n{2}",
                        PWWrapper.aaApi_GetLastErrorId(),
                        PWWrapper.aaApi_GetLastErrorMessage(),
                        PWWrapper.aaApi_GetLastErrorDetail());
            public static void ShowUsageAndExit()
                Console.WriteLine("");
                Console.WriteLine("======");
                Console.WriteLine("Usage:");
                Console.WriteLine("{0} [-d Server:Datasource] [-u Username] [-p Password]", Process.GetCurrentProcess().ProcessName);
                Console.WriteLine("------");
                Console.WriteLine("Notes:");
                Console.WriteLine("Command line arguments override the values in {0}.config.", Process.GetCurrentProcess().ProcessName);
                ExitApp(-1);
            public static void ExitApp(int ExitCode)
                // When in the debugger, the console window will stay open.
                if (Debugger.IsAttached)
                    Console.Write("Press any key to exit console window when in debug mode...");
                    Console.ReadKey();
                Environment.Exit(ExitCode);
            static void Main(string[] args)
                GetApplicationDefaultProperties();
                GetUserSpecifiedValuesFromCommandLine(args);
                // Initialize the PW APIs
                PWWrapper.aaApi_Initialize(0);
                // Before we login, we can check to see what version of ProjectWise are we using.
                // This will be the version of ProjectWise Explorer on this machine.
                Int32 MajorHigh = 0;
                Int32 MajorLow = 0;
                Int32 MinorVersion = 0;
                Int32 BuildNo = 0;
                if (!PWWrapper.aaApi_GetAPIVersion(ref MajorHigh, ref MajorLow, ref MinorVersion, ref BuildNo))
                    // In generaly, it is a good practice to check if a method worked or not
                    ShowPWError();
                    PWWrapper.aaApi_Uninitialize(); // good practice
                    ExitApp(-2);
                else
                    Console.WriteLine("ProjectWise Explorer Version {0}.{1}.{2}.{3}", MajorHigh, MajorLow, MinorVersion, BuildNo);
                try
                    using (PWSession myPWSession = new PWSession(sDatasourceName, sUserName, sPassword))
                        // Determine who has logged in.
                        int userId = PWWrapper.aaApi_GetCurrentUserId();
                        if (userId == 0)
                            ShowPWError();
                            PWWrapper.aaApi_LogoutByHandle(PWWrapper.aaApi_GetActiveDatasource()); // good practice
                            ExitApp(-4);
                        else
                            Console.WriteLine("Logged into Datasource '{0}' with Username '{1}' successfully.",
                                sDatasourceName,
                                sUserName);
                            // get some info about the current user
                            if (PWWrapper.aaApi_SelectUser(userId) != 1)
                                ShowPWError();
                            else
                                Console.WriteLine("User id={0}, Name='{1}', Description='{2}', Email='{3}'",
                                    userId,
                                    PWWrapper.aaApi_GetUserStringProperty(PWWrapper.UserProperty.Name, 0),
                                    PWWrapper.aaApi_GetUserStringProperty(PWWrapper.UserProperty.Desc, 0),
                                    PWWrapper.aaApi_GetUserStringProperty(PWWrapper.UserProperty.Email, 0));
                        // A good practice is to Logout and unitialize
                        if (!PWWrapper.aaApi_LogoutByHandle(PWWrapper.aaApi_GetActiveDatasource()))
                            ShowPWError();
                            ExitApp(-5);
                        else
                            Console.WriteLine("Logged out.");
                catch (Exception ex)
                    // using the Exception message
                    Console.WriteLine(ex.Message);
                    // optionally
                    Console.WriteLine("StackTrace: {0}", ex.StackTrace);
                    // no point in continuing
                    ExitApp(-3);
                // All done, but we want to keep the console window open in debug mode...
                ExitApp(0);
    Here's a link: https://communities.bentley.com/products/programming/projectwise_programming/m/mediagallery/273950
    Dan Williams
    Solution Consultant
    Bentley Systems, Incorporated
    Portland, OR, USA (Pacific Time UTC-08:00)
  • The full code for the sample login can be found here: https://github.com/DanWilliamsAtBentleyDotCom/Sample-Login-CSharp-For-ProjectWise
    Dan Williams
    Solution Consultant
