Can we call a clickonce application written in C# from projectwise explorer ? If yes, how?
Any sample code would be helpful.
Aparna
Please see below, that can help you to start something:
github.com/.../MostOfDavesClasses-CSharp-Wrappers-For-ProjectWise
communities.bentley.com/.../273950
Thanks for link and also thanks for Dave putting the time and energy into this - however its still not good enough from Bentleys perspective.
I'm a bridge engineer with some coding knowledge who likes to chip in now and again to help provide tools for my department to eliminate chunks of tedious work for many people.
I'm a hobbyist, not a professional software developer, and don't have the time to fiddle/understand exactly how the workaround operates which on the surface seems very complicated to someone like myself.
We want a simple API to be able to plug into and use - something many other software packages e.g. FE programs have been capable of for years that are written in C++/C. While I'm not 100% sure of this, I'm not comfortable plugging into an unmanaged language like C++ using unsafe code which could potentially corrupt 100s of thousands of pounds worth of data.
Apologies if this post comes off as shirty but its been 6 years in the making apparently (!), and nothing will get done unless you nag for it.
Pete
I would believe the link ( https://communities.bentley.com/products/programming/projectwise_programming/m/mediagallery/273950 ) can support you to start as it contains a sample login program done using VS c#. You have to read through the SDK to get more.
You have a point of your comp
PowerShell may be the simple API you are looking for. Very powerful library and simple to execute. I was able to do things with it that would have taken me a month to code. Using either C# or C++ API is not trivial.
