Creating new work area attributes using PW SDK
I'm having some difficulty creating new work area attributes using the SDK (aaOApi_CreateAndInitializeAttribute), specifically assigning the control type i.e. none, pick list or select:
using the following function the attribute is created but it assigns Pick List as the Type. How do I set 'None' as the type?
aaOApi_CreateAndInitializeAttribute(
    ref attrId,
    ref ppNewAttribute,
    "Project_Test",
    "Test Label",
    "Test Description",
    5,
    50,
    0,
    "Project_Test",
    false
I'm also struggling to assign the default value using 'aaOApi_SetAttributeDefValue'
