Would it be possible to create a cmdlet for getting a list of available Workspace Profiles and possibly Managed Workspace Configuration Blocks within a datasource?
You should direct this over to the PowerShell Forum. But, since I happened to see this here, we do know that we need some workspace management cmdlets. Planning on adding when I get a chance. Not as straightforward as I'd hoped it would be. Dave.
Sorry. Thought I landed in the right spot...but clearly not. I posted again in the correct form. Thanks for the heads up.
Mark KovachAtkinsRéalisDesign Systems Integrator | IT Design & Engineering SolutionsInformation Technology ServicesEngineering, Design and Project ManagementProjectWise CONNECT Edition | PowerShell | Power Automate
