How to create server directory programmatically in Projectwise? which api to use?
Jeffrey,
"Words get in the way", as I like to say. What exactly are you trying to do? The more information you provide, the more likely you will get a meaningful response.
Pictures, i.e. screen shots, etc. are very helpful.
Specifically, I don't know what you mean by "server directory in ProjectWise". My best guess is that you are asking how to create a folder that you see in ProjectWise Explorer. For that, search the ProjectWise SDK help for "folder", "project", "vault", or "rich Project".
The most straight forward API function would be aaApi_CreateProject(), but then you will likely want to modify some of the newly created project's (folder) properties.
