If I have two dwg documents checked in. I create a set parent-child, using aaApi_CreateLSet success.
aaApi_SelectNestedReferencesList returns null.
If I run scan references on the parent in explorer, aaApi_SelectNestedReferencesList sometimes works, but sometimes the set is deleted.
I must be missing a step, any tips on why?
Cheers:)
edit: aaApi_SelectNestedReferencesList last error is PW API error, code=50000, error=Not found.:
void Tests::testcreatePwLSet(PwDocument& parent, PwDocument& child) { LONG setID = -1; LONG memberID = -1; LONG lRelationType = AADMS_SETMEM_REF; LPCWSTR lpctstrTransfer = AADMS_SETMEM_COPY; if (FALSE == aaApi_CreateLSet(&setID, parent.projectId(), parent.documentId(), child.projectId(), child.documentId(), lRelationType, lpctstrTransfer, &memberID)) { pwApp.promptLastError(_T("aaApi_CreateLSet failed")); return; } std::array<TCHAR, MAX_PATH> pwpFullPath = { 0 }; std::array<TCHAR, MAX_PATH> pwcFullPath = { 0 }; for (int i = 0, cnt = aaApi_SelectSet(setID); i < cnt; i++) { LPCGUID pguid = aaApi_GetSetGuidProperty(SET_PROP_PDOCGUID, i); LPCGUID cguid = aaApi_GetSetGuidProperty(SET_PROP_CDOCGUID, i); aaApi_GUIDGetDocumentFileName(pguid, pwpFullPath.data(), pwpFullPath.size()); aaApi_GUIDGetDocumentFileName(cguid, pwcFullPath.data(), pwcFullPath.size()); acutPrintf(_T("\nparent=%ls, child = %ls"), pwpFullPath.data(), pwcFullPath.data()); //OK } testPwSet(parent); } void Tests::testPwSet(PwDocument& parent) { GuidListP pList = aaApi_SelectNestedReferencesList(parent.projectId(), parent.documentId(), 0, -1); if (pList != nullptr) { LPCGUID pGUID = aaApi_GuidListGetFirstGuid(pList); while (pGUID != nullptr) { for (int i = 0, cnt = aaApi_GUIDSelectDocument(pGUID); i < cnt; i++) { const auto id = aaApi_GetDocumentNumericProperty(DOC_PROP_ID, i); const auto name = aaApi_GetDocumentStringProperty(DOC_PROP_NAME, i); acutPrintf(_T("\n%ld %ls"), id, name); } pGUID = aaApi_GuidListGetNextGuid(pList); } aaApi_GuidListDestroy(pList); } else { pwApp.promptLastError(); } }
so it seems aaApi_CreateReferenceInformation2 is needed to generate this information. however its not clear how to use this function.
since there's zero documentation on this. things start to break when I have a tree structure of files with links created by aaApi_CreateLSet and aaApi_AddLSetMember
so its not clear on how to append a child using aaApi_CreateReferenceInformation2.
How do I run the scan tool that;s in explorer from API?
Sets and references are a major feature and should have sample code.
I plan on releasing just using logical sets since the behavior works, in that PW copies out 1st generation children. Hopefully it works and our mutual customers are happy : )
Nested references are not being copied out, even though they show in the Dependency viewer, any ideas why?
bool PwFileDependencyManager::createPwFileReference(const PwDocument& parent, const PwDocument &child, ETransferMode mode) { LONG setID = -1; LONG memberID = -1; LONG lRelationType = AADMS_SETMEM_REF; LPCWSTR lpctstrTransfer = AADMS_SETMEM_COPY; if (!parent.isIDValid()) { pwApp.promptLastError(_T("Invalid parent document")); return false; } if (!child.isIDValid()) { pwApp.promptLastError(_T("Invalid child document")); return false; } switch (mode) { case PwFileDependencyManager::eNone: lpctstrTransfer = AADMS_SETMEM_TFRNOTDEF; break; case PwFileDependencyManager::eCopy: lpctstrTransfer = AADMS_SETMEM_COPY; break; case PwFileDependencyManager::eCheckout: lpctstrTransfer = AADMS_SETMEM_CHECKOUT; break; } if (PwFileDependencyManager::hasPwReference(parent, child)) { return false; } if (const int nCnt = aaApi_GetSetCount(parent.projectId(), parent.documentId(), -1, -1); nCnt > 0) { if (const int nRefs = aaApi_SelectSetReferences(parent.projectId(), parent.documentId()); nRefs > 0) { if (setID = aaApi_GetSetId(0); setID > 0 && !aaApi_AddLSetMember(setID, child.projectId(), child.documentId(), lRelationType, lpctstrTransfer, &memberID)) { return false; } } } else if (!aaApi_CreateLSet(&setID, parent.projectId(), parent.documentId(), child.projectId(), child.documentId(), lRelationType, lpctstrTransfer, &memberID)) { return false; } return true; } bool PwFileDependencyManager::hasPwReference(const PwDocument& parent, const PwDocument& child) { return aaApi_GetSetCount(parent.projectId(), parent.documentId(), child.projectId(), child.documentId()) > 0; }
I add references starting with the children, working my way up to the parent. it show correctly in the Dependency viewer
but nested children aren't copied out
I found a work around my iterating the set and copying out the files, immediately after calling aaApi_DocumentSelectDlg, seems like a hack though
