In project explorer, if I export a file to some random folder on my local drive, how can I obtain said file’s information? I.e. projid, docid, and status of exported, from just the exported path?
aaApi_GetProjectIdFromFileName2 seems to only search if there’s a valid PW_WORKDIR in the path
How does explorer know where to reimport the files from? I assume the exported file path is stored somewhere.
Cheers Dan
Daniel,
Take a look at the "Location Functions" in the SDK help under "Modules > ProjectWise DMS API > "
And in particular, the contents of the buffer AADMSBUFFER_CHKL.
You should be able to determine what you need from the buffer populated using one of the aaApi_SelectLocation... functions.
Answer Verified By: Daniel Marcotte
Thanks Dan!
Works perfectly!
