Adding folder propeties to a datatable for reporting
All,
So i am writing a script to gather information about folders in a project, checking for Environment, Workflow etc...
i created a datatable so i can use that to create the excel file.
however i am getting the following error when adding a row to the datatable
PS C:\WINDOWS\system32> $dr = $GET_FoldersDT.NewRow()
Method invocation failed because [PWPS_DAB.CommonTypes+ProjectWiseFolder] does not contain a method named 'NewRow'.
At line:1 char:13
+ $dr = $GET_FoldersDT.NewRow()
+ CategoryInfo : InvalidOperation: (:) [], RuntimeException
+ FullyQualifiedErrorId : MethodNotFound
Below is the snipit of code where i am setting the datatable, and looping through the folders
$FolderReportDT = New-Object System.Data.DataTable ("Folder Report")
#Going to create the specific columns to store the work are infomration, participant count, and document count
$FolderReportDT.Columns.Add("Folder Name")
$FolderReportDT.Columns.Add("Folder Environment")
$FolderReportDT.Columns.Add("Folder Workflow")
$FolderReportDT.Columns.Add("Folder Document COUNT")
$FolderReportDT.Columns.Add("Folder Creator")
$FolderReportDT.Columns.Add("Folder Owner Name")
$FolderReportDT.Columns.Add("Folder URN")
New-PWLogin
Get-PWCurrentDatasource
$StartedFrom = (Show-PWFolderBrowserDialog).FullPath
$GET_FoldersDT = New-Object System.Data.DataTable
$GET_FoldersDT = Get-PWFolders -FolderPath $StartedFrom -PopulatePaths
Write-Host "there are " $GET_FoldersDT.count " folders found"
foreach($DT_Row in $GET_FoldersDT)
TIA
Stephen
