Hi all,
I am using aaApi_DeleteDocumentWithGUI and aaApi_GUIDDeleteProject to delete Documents and Folders in a Custom ProjectWise Explorer add-in and noticed that these deleted items do not get sent to the (relatively new) Deleted Items folder.
Does anyone know how i can get these deleted Documents / Folders to be sent there as a safeguard mechanism?
Seeing that we're now getting used to having Recycle Bin functionality, any add-ins we make that delete items would need to use this.
Mark
Unfortunately, it isn't obvious how to do a "soft delete".
Try something like this:
#define TOTRASH 0x00000040 if (!aaApi_DeleteDocument(TOTRASH, lProjectId, lDocumentId)) { // error... }
I'm not sure if this behaves the same with with aaApi_DeleteDocumentWithGUI(), but it probably does.
(sorry my first posting had the wrong mask...)
Thanks Dan, worked perfectly. You wouldn't know what the Project Delete flag equivalent is?
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 16.3 | ProjectWise CE 3.4
As far as I know it's not documented but it's implemented in the PowerShell module where I extracted the following enum.
public enum DocumentDeleteMasks { IncludeVersions = 8, MoveAction = 4, None = 0, NoSetChild = 1, NoSetParent = 2, ToTrash = 0x40 }
Thanks Rob, you don't see any ProjectDeleteMasks in there that have a "ToTrash" flag for folders?
Hi Mark, no it doesn't look like the PowerShell cmdlet Remove-PWFolder has implemented the same soft delete recycle bin functionality so I don't see a ProjectDeleteMasks definition.
