Hi all,
I am having difficulty in creating a utility function to return a list of all open connections for an application. I can get a count of the open connections using aaApi_GetOpenDsHandles(ref dsCount); however the Pointer that is returned by the function does not seem to be accepted by aaApi_GetDatasourceNameByHandle. Perhaps this is because it is a pointer to an array of pointers since it will return multiple handles one for each datasource? Here is the code I have so far:
//Wrappers [DllImport("dmscli.dll", CharSet = CharSet.Unicode)] public static extern IntPtr aaApi_GetOpenDsHandles ( ref int Count ); [DllImport("dmscli.dll", CharSet = CharSet.Unicode)] public static extern bool aaApi_GetDatasourceNameByHandle ( IntPtr hDataSource, StringBuilder StringBuffer, int BufferSize ); //Code //Login to 2 different datasources (for testing purposes) PWWrapper.aaApi_LoginDlg(PWWrapper.DataSourceType.Unknown, null, 0, null, null, null); PWWrapper.aaApi_LoginDlg(PWWrapper.DataSourceType.Unknown, null, 0, null, null, null); int dsCount = -1; StringBuilder dsNames = new StringBuilder(1024); IntPtr hDataSource = PWWrapper.aaApi_GetOpenDsHandles(ref dsCount); if (dsCount > 0) { PWWrapper.aaApi_GetDatasourceNameByHandle(hDataSource, dsNames, dsNames.Capacity); // Returns false - According to the SDK: "The passed handle is NULL or it does not specify a datasource" } bool freeDSPtrs = PWWrapper.aaApi_Free(hDataSource); Debug.Print(freeDSPtrs.ToString());
If I know the datasource name/s then using aaApi_GetDatasourceHandlesByName does get me the handle, however it would be useful to see a list of all open connections for this specific task.Thanks,Edward
Resolved this issue now, as expected I needed to iterate over the Pointer array. Working Code:
public static Dictionary<string, IntPtr> GetOpenDataSourceConnections() { // Initialise variables Dictionary<string, IntPtr> connections = new Dictionary<string, IntPtr>(); int dsCount = -1; int typeSize = Marshal.SizeOf(typeof(IntPtr)); StringBuilder dsName = new StringBuilder(256); IntPtr hDataSource = PWWrapper.aaApi_GetOpenDsHandles(ref dsCount); for (int i = 0; i < dsCount; i++) { IntPtr dsPtr = Marshal.ReadIntPtr(hDataSource, i * typeSize); PWWrapper.aaApi_GetDatasourceNameByHandle(dsPtr, dsName, dsName.Capacity); connections.Add(dsName.ToString(), dsPtr); } return connections; }
Answer Verified By: Edward Ashbolt
