Hi all,
Has anyone had any issues being able to retrieve/select the documents in a document array using the SDK in VBA? I know how to do this in C++ and C#, but am struggling finding a method that works for me in VBA.
I've tried different methods, including collections and arrays and everything I try results in a crash. I can retrieve the info for a single document quite easily (from different functions like the Open/Select dialog, data from buffer, etc.).
Any help would be appreciated.
Mark
The problem with VBA is pointers and UNICODE. Check this out: communities.bentley.com/.../problem-using-the-projectwise-sdk-with-vba-in-microsoft-access
