My app. for PW Explorer in MicroStation CONNECT works fine. It runs some checks on a number of DGN files.
However, when the app starts, the active DGN document may be checked-out and PW prompts the user to check-in. That is, the MicroStation user may or may not see PW's check-in prompt dialog.
How can I find the PW identity of the active DGN file? With its PW project and document ID I can then check-in programmatically so the user doesn't see the prompt from PW.
