I want to create a customer document file property, which api should I use, is there some sample code?
Hi Peter,
please be aware this is general Developers and Programming forum.
From your question, it's not clear what product and version do you use and what language (C++, NET, VBA) do you prefer, so it cannot be answered.
If it's about MicroStation, I recommend to move it to MicroStation Programming forum (or to another <product> programming forum). To move existing discussion, use More > Move tool available under your original post.
With regards,
Jan
Thanks for you reply.
I want to use the Projectwise SDK API to create a "Document Custom Properties", like "Document_Department" in the following capture.
Peter Wen said:I want to use the Projectwise SDK API
In such case move this discussion to ProjectWise Programming forum.
Yes, it's better to move this discussion to ProjectWise Programming forum.
But I don't know how to move, could you help to move or give some guild for how to move.
Thanks!
Peter Wen said:But I don't know how to move
I wrote it already in my first reaction. You did not read it?
Use More > Move tool, available under your original post.
