Is it possible to create projects/directories under others via the BWSG API?
Nothing seems to be listed in documentation, though if I try to create a new NavNode under another I get a policy error so it appears to be possible, but uncertain on if that's a generic error when creating a new NavNode under a directory
Were you able to figure it out? Thank you.
NavNode schema is for navigation. You should use PW_WSG schema with Project class . Use properties
