Inspired by this thread
https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/108454/v8i-mdl-how-to-call-projectwise-api-from-native-code-mdl/329450#329450
I'm trying to call the ProjectWise API from MDL/cpp. I would like to get the active datasource, project and document from PW Explorer and I've tried to do it this way:
if (aaApi_Initialize(AAMODULE_EXPLORER)) { aaApi_InitializeModules(AAMODULE_ALL); HDSOURCE dataSource = aaApi_GetActiveDatasource(); if (dataSource == NULL) lifalib_dmsg("NULL"); else lifalib_dmsg("ActiveDatasource OK"); lifalib_dmsg("Count = %d", aaApi_GetProjectCount());
The dataSource is NULL and the number of projects is -1...
There is no problem in find a datasource by name:
HDSOURCE *pdataSource; ULong count; if (aaApi_GetDatasourceHandlesByName(L"Test", &pdataSource, &count)) lifalib_dmsg("OK"); else lifalib_dmsg("NOT OK");
What am I missing or doing wrong ?
Evan H. Hansen
Any news regarding this issue ?
Of course your code work fine in our environment Since you are a member of BDN we have contacted you to arrange a screen sharing session.
Mark Weisman | Senior Consultant | Bentley Systems, Inc.
