[Explorer API CE] How can I get active datasource and active document ?
Inspired by this thread
https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/108454/v8i-mdl-how-to-call-projectwise-api-from-native-code-mdl/329450#329450
I'm trying to call the ProjectWise API from MDL/cpp. I would like to get the active datasource, project and document from PW Explorer and I've tried to do it this way:
if (aaApi_Initialize(AAMODULE_EXPLORER))
		aaApi_InitializeModules(AAMODULE_ALL);
		HDSOURCE dataSource = aaApi_GetActiveDatasource();
		if (dataSource == NULL)
			lifalib_dmsg("NULL");
		else
			lifalib_dmsg("ActiveDatasource OK");
		lifalib_dmsg("Count = %d", aaApi_GetProjectCount());
The dataSource is NULL and the number of projects is -1...
There is no problem in find a datasource by name:
		else
What am I missing or doing wrong ?
I'm using MicroStation CE upd. 15 and PW Explorer ver. 10.0.3.334.
Evan H. Hansen
