I am trying to execute a saved search via PW API, and would like to return all attributes from a specific environment along with the results. So far I have the following code:
public static int GetSavedSearchQueryId(string searchName, int parentQueryId, int projectId, bool personal) { int user = personal ? PWWrapper.aaApi_GetCurrentUserId() : 0; IntPtr databuffer = PWWrapper.aaApi_SQueryDataBufferSelectSubItems2(parentQueryId, user, projectId); int count = PWWrapper.aaApi_DmsDataBufferGetCount(databuffer); for (int row = 0; row < count; ++row) { string queryName = PWWrapper.aaApi_DmsDataBufferGetStringProperty(databuffer, 6, row); if(queryName == searchName) { int queryId = PWWrapper.aaApi_DmsDataBufferGetNumericProperty(databuffer, 1, row); return queryId; } } return 0; } static void GetPWDocumentsBySavedSearch(string searchName, int projectId, bool personal, bool populatePath) { int queryId = Utils.GetSavedSearchQueryId(searchName, 0, projectId, personal); // This returns the "Query ID" of the saved search DataTable result; if (queryId > 0) { //Saved search found result = PWSearch.SearchForDocumentsByQueryId(queryId, populatePath); //This will return a DataTable with the list of documents found } }
This all works fine, however I am struggling to figure out how I can best add custom attributes into the search results. It seems there are a couple of options available:
Not sure if there are any other options that I've missed. Option 2 seems to be a lot more complex in comparison to option 1, given that it requires structs that don't make much sense to me after reading the documentation. It appears as though I need to do something like the following:
// 1. Select Criteria buffer IntPtr criteriabuffer = PWWrapper.aaApi_SQueryCriDataBufferSelect(queryId); // 2. Generate list of DocumentRequestColumns (the hard part!) PWWrapper.DocumentRequestColumns requestColumns = new PWWrapper.DocumentRequestColumns() {//No idea what I'm doing here, the documentation is confusing me :D properties = { ??? }, padding = ???, columns = { ??? } }; // 3. Execute search bool cancel = false; IntPtr results = IntPtr.Zero; PWWrapper.aaApi_FindDocumentsToBuffer(criteriabuffer, requestColumns, ref cancel, ref results);
But the reality is I don't know how to generate that struct properly... If anyone has any pointers (pardon the pun) please let me know!Thanks,Edward
It seems like there might be one more option available, however I cannot get it to work for some reason:
int selEnv = PWWrapper.aaApi_SelectEnvByProjectId(157085); int envId = PWWrapper.aaApi_GetEnvId(0); result = PWSearch.SearchForDocumentsUltimate( 157085, // ProjectID true, // Search sub folders null, // Search string false, // Match whole phrase false, // Any words true, // Search attributes null, // Document name null, // File name null, // Document desc true, // Originals only new SortedList<string, string>(), // Attribute list 0, // Latitude min 0, // Longitude min 0, // Latitude max 0, // Longitude max false, // Spatial second pass new List<int>() { envId }, // List environments new List<int>(), // List states new List<int>(), // List workflows new List<int>(), // List storages new List<int>(), // List applications new List<string>(), // List statuses new List<int>(), // List item types new List<int>(), // List creators new List<int>(), // List updaters new List<int>(), // List checked out users 0, // Final status null, // File updated after null, // File updated before null, // Doc updated after null, // Doc updated before null, // Doc created after null, // Doc created before null, // Doc checked out after null, // Doc checked out before populatePath, // Populate path new List<string>() { "RV_REV_1" }, // List columns "Test", // Query name 0, // Query parent project id 0); // Parent query id int count = result.Rows.Count; // Returns 0 results
Not sure why this isn't working regardless of what I put as the inputs. I have tested other PW search methods and they all function as expected, but don't seem to provide the options to use both a saved query AND specify return columns at the same time. For example this works fine:
result = PWSearch.SearchForDocumentsWithStatesAndDatesAndReturnColumns(157085, true, null, false, false, true, null, null, null, true, envId, new SortedList<string, string>(), new List<int>(), null, null, null, null, true, new List<string>() { "RV_REV_1" });
But I cannot use a saved query with it, and it does not return the file update date. If only I could get the "SearchForDocumentsUltimate" working, it seems that should satisfy all criteria!
I have decided just to use the search function PWSearch.SearchForDocumentsWithStatesAndUpdateDatesAndReturnColumns() for now:
//Get attribute columns int envId = PWWrapper.GetEnvironmentId("DOC-01"); List<string> envColNames = PWWrapper.GetAttributeColumnNamesFromEnvironment(envId).Keys.Cast<string>().ToList(); //Get states List<int> states = new List<int>(); states.Add(PWWrapper.GetStateId("Shared")); states.Add(PWWrapper.GetStateId("Published")); //South (STH) attributes to search SortedList<string, string> sthAttSearchValues = new SortedList<string, string>(); //attSearchValues.Add("DC_TYPE", "MD2"); //attSearchValues.Add("DC_TYPE", "MD3"); sthAttSearchValues.Add("DC_CONTRACT", "STH"); DataTable sthDT = PWSearch.SearchForDocumentsWithStatesAndUpdateDatesAndReturnColumns(91106, true, "", false, false, false, "", "", "", true, envId, sthAttSearchValues, states, null, null, true, envColNames);
Just an update - for those wanting to perform searches outside the scope of what the PWSearch.dll lib provides: You can actually just create SQL Queries to achieve the same, and even store it as a custom view in the db if need be. I have found this approach to be much more flexible and equally performant, however it comes at the cost of some additional complexity when building the select statements if you have many search parameters and need to join multiple tables (e.g. dms_doc, dms_proj, custom_environment).
Answer Verified By: Edward Ashbolt
