Hi all,I have been attempting to push a document to a different state using the aaApi_WREDoExecute method listed in the API. Everything seems to be working to a certain degree, except the response I get is: "Execution command identifier '{urn:bentley:wre:command:__1_1_REVISE__}' not recognized".
Is there perhaps a syntax error in the command Id I used within the aaApi_WRECreateExecuteDescription method? Not sure what it is though since I have tried a number of different combinations with no luck. The "command id" value was generated using the aaApi_WREAskCommands method, which returned this comamnd id as one of the commands available for that document.
Any suggestions or help would be greatly appreciated!
Edward
Found the solution... the aaApi_WREDoExecute example in the documentation is incorrect: aaApi_WRECreateExecuteDescription does not take an array for the command id, it just takes a single command id (no curly brackets). Once I changed that everything worked as expected!
so aaApi_WRECreateExecuteDescription(document, "{my-command-id}");
becomes aaApi_WRECreateExecuteDescription(document, "my-command-id");
Answer Verified By: Edward Ashbolt
This is really interesting and useful.
Try to get WRE running as well, but cant command id.
The ID what I set from Rules engine did not work, like Nextstate
How did you get manage to work aaApi_WREAskCommands?
Darius
Hi Darius,
You need to use the aaApi_WREAskCommands method to query for the id using the command "label", eg.
//Retrieve commands list IntPtr commandsRequest = PWWrapper.aaApi_WREAskCommands(request); IntPtr commandsList = PWWrapper.aaApi_DmsDataBufferGetBufferProperty(commandsRequest, DMS_WRE_COMMANDS_COMMANDS, 0); int commandsCount = PWWrapper.aaApi_DmsDataBufferGetCount(commandsList); //Get each command available for (int i = 0; i < commandsCount; ++i) { string label = PWWrapper.aaApi_DmsDataBufferGetStringProperty(commandsList, DMS_WRE_COMMAND_LABEL, i); if (label.StartsWith(commandLabel, StringComparison.OrdinalIgnoreCase)) { cmdId = PWWrapper.aaApi_DmsDataBufferGetStringProperty(commandsList, DMS_WRE_COMMAND_ID, i); break; } }
Thanks a lot Edward, helped so much!!!
Finally I managed to run Rules engine using API.
There is one interesting situation. When I run this command not from PW client, but use third application, login to PW data source it works fine. The problem is when I try do exactly the same from active PW client session, I just go out from execution, no warning, no errors.
It just return back to the session. Try{} catch{} do not get anything.
I get this problem on aaApi_DmsDataBufferSetBufferProperty.
Not sure what is wrong.
IntPtr requestCmd = PWWrapper.aaApi_WRECreateCommandsRequest("en");IntPtr documents = PWWrapper.aaApi_DmsDataBufferGetBufferProperty(requestCmd, 2, 0);IntPtr document = PWWrapper.aaApi_WRECreateDocumentIdentifier("{" + docGuid + "}");PWWrapper.aaApi_DmsDataBufferAppend(documents, document, 0, 0);PWWrapper.aaApi_DmsDataBufferSetBufferProperty(requestCmd, 2, 0, documents);
Best regards
Hard to say what the issue would be without more information. A few things you could check:
Hope that helps
