I am currently experimenting with ProjectWise connectors for Power Automate. I have setup a flow that extracts the references from federated models (models within models within models, composed of various filetypes i.e. 2D models, i-models etc.) within a folder. I believe that the connector ignores nesting (or has its nesting depth set to 99) meaning the all the references for the references attached to a federated model are also retrieved and so on. It would be very useful to be able to retrieve references at a certain nesting depth using the connector or otherwise know what reference is attached to what model.
Is there the possibility that this could be added as a capability to the connector otherwise, has anyone come across this problem and found a reliable solution?
Adam Chidwick
