Do we need to fill a buffer or something prior to calling the aaApi_UserManagementDlg function in order for it to function correctly?
The dialog displays on the screen okay, but left most list control only shows the default root nodes which do not expand because they are void of sub-nodes, and when using the "Search" feature it crashes the application.
Todd
P.S. We are Logged Into the Datasource as an Admin
This issue has been resolved - needed to change the Target Platform from 64bit to the x86 32bit Platform
Answer Verified By: Todd Jacobs
