Having an issue using the Import-PWvies command in PowerShell. I've used the Export-PWViews to export the view I need to have in all of my datasources. When I try to do the import using the following in just processes for about a minute and then restarts my Powershell:
Import-PWViews -InputFileName C:\Temp\Pwise\Export\Views\ViewFile.xlsx -ViewNames ImportView -OverwriteExistingViews
I've tried this with PWPS_DAB version 2.1.3.0 and 2.1.10.0 with the same result. There are no errors and nothing is changed in the datasource. Has anyone else see this happen.
Frank
Try turning on -verbose, that might give an idea of what's going on. in 2.1.10.0 for me it lists each view and it's columns as it creates them.
This worked fine for me but I did have to log out of the datasource and log back in before I could see the imported views.
Could it be caused by a mismatch in Environment assigned to a view? My test views didn't have environments.
Hi Kevin, Thanks for taking a look at this. I tried to add -verbose to the import command. I ran the export with an environment associated and without. I got the same result on the imports. The import processes the first 4 attributes of the view and then it restarts the powershell session. Loging out of the datasource and back in there is no view created.
Wow, that's a big crash. Are you running 32 or 64-bit powershell? If 32, try the 64-bit.
Yea. I'm using 64-bit on everything. I'm resorting to creating them manually in my production datasources. But it sure would be nice it this worked. I need to put at least 1 view in 12 datasources.
What version of explorer is installed?
