Hello community,
I'm new to ProjectWise and Bentley, nice to meet you here.
I'd like to build a web application that consumes data from ProjectWise. After some googling, I discovered this Getting Started: Bentley Web Services Gateway (WSG)
that I need to install the Bentley web service gateway and configure stuff.
I also noticed that we can access data from Bentley Connect through web browser, so I wonder is there a REST API for ProjectWise that developers can retrieve data?
Please advice, thank you very much!
Cheers,
Chloe
Hi Chloe,
be aware this is general developers and programming forum. Because your question is specifically about ProjectWise, I recommend to move your question to ProjectWise Programming forum.
To move existing discussion to another forum, use More > Move tool, available under your original post.
With regards,
Jan
Hi Chloe, did you get any solution to your question? I am also new to projectwise. I have requirement to automatically extract data from bentley projectwise thru API. Do you know how? Thanks
