Is there any way of knowing that you are processing the first document in a batch when you're in a hook function?Specifically, I'm wanting to prompt the user if they want to copy attributes to a document being imported, and--if they import a batch of them--give them the option of applying their response to all of the documents in the batch. But since the Pre- and Post-Hook functions are called for each document individually, I can't figure out how to know where we are in the submitted batch.
In case anyone wondered, a co-worker helped to figure out a solution. Here are the relevant pieces.// Add this hook function to catch a drop to folder aaApi_AddHook (AAHOOK_IMPORTBYDROPHANDLE, AAACTIONHOOK, DropDocument_ActionHook);
// Function to catch a drop to a folderLONG AAAPIHOOK DropDocument_ActionHook( LONG hookId, LONG hookType, AAPARAM aParam1, AAPARAM aParam2, AARESULT* pResult) {...
if (aParam2 != AAOPER_DLG_IMPORTBYDROPHANDLE) return AAHOOK_SUCCESS; AAPROJECTDLG_PARAM * p = (AAPROJECTDLG_PARAM *) aParam1;
// Get dropped file count UINT uiCount = DragQueryFile ((HDROP)p->lpParam , (UINT)-1, (LPWSTR)NULL, 0);
// Get dropped file names for (UINT i = 0; i < uiCount; i++) { WCHAR tchFileName[AAAPI_MAX_FILENAME]; if (!DragQueryFile ((HDROP)p->lpParam, (UINT)i, (LPWSTR)tchFileName, AAAPI_MAX_FILENAME)) {...
