How to upload a document using Projectwise API's ( Via web services gateway)?
I recommend to move your question to ProjectWise programming forum.
To move existing thread to another forum, use More > Move tool, available under your original post.
Jan
Done, Thanks.
Hi SMS ,
By clicking the associated "Wiki" icon above for this forum you may find some additional helpful information.
For your question please take a look at: WSG-RESTAPI Topic > Getting Started: Bentley WSG REST API.
Note ProjectWise PowerShell Extensions are also referenced and recommended to help accomplish certain automated and/or admin tasks quickly with little effort.
Once on the WSG getting started page take a look to the (code behind):..\Server\Pages\WSGExplorer.aspx which provides a File Upload feature.
The code behind is primarily located in the files: wsgExplorer.js+28 and wsgApi.js+290 and make calls to some generic multi-purpose HTTP setup methods where you may want to set a breakpoint and debug to see/examine the full formatted ajax http request header generated.
HTH,Bob
Hi Bob,
Thank you for your guidance. will check this topic and see.
