ProjectWise SDK (C++) / Powershell
Hello All,
I am developping a script to do some activity on all the projects inside the ProjectWise with using the SDK (C++). The plan is to generate a DLL file and import in Powershell to get input as a parameter. Below are the code that i am using in the C++ environment. But some issues that i cannot suceed to load in powershell. It would be great if someone correct me what i have done a wrong. I cannot put my detailed function here, but i placed the main function here.
C++
#include "pch.h"
#include <iostream>
#include <string>
#include <Windows.h>
namespace MyNamespace {
    class MyDLLClass {
    public:
        static void InputData(const char* var1, const char* var2, const char* var3) {
            std::cout << "Received data in InputData function:" << std::endl;
            std::cout << "Variable 1: " << var1 << std::endl;
            std::cout << "Variable 2: " << var2 << std::endl;
            std::cout << "Variable 3: " << var3 << std::endl;
// Entry point function for the DLL
extern "C" __declspec(dllexport) void RunDLL() {
    std::cout << "DLL is running..." << std::endl;
int main()
    std::cout << "Starting process!\n";
    aaApi_Initialize(AAMODULE_EXPLORER);
    SetShellInput MainInput;
    LPCWSTR lDatasource = 'XXXXX';
        LPCWSTR projectName = 'XXXX';
    LPCWSTR uniqueID = 'XXXX';
    LPCWSTR usrlistName = 'XXXXX';
    bool loginSuccess = loginDatasource(lDatasource);
    if (loginSuccess == true)
        std::cout << "SUCCESS!\n";
    else
        long errorID = aaApi_GetLastErrorId();
        std::cout << "FAILURE!\n";
    long projectID = getProjectID(projectName);
    if (projectID > 0)
        LONG viewerUserListID = getUserlistIDBySQL(usrlistName);
        makeProjectReadOnly(projectID, uniqueID, viewerUserListID);
    aaApi_Uninitialize();
PowerShell
# Load the DLL
$dllPath = "C:\Temp\DLL\DLLPSImport.dll"
Add-Type -TypeDefinition @"
    public class MyDLLClass {
        public static void ProcessData(string var1, string var2, string var3) {
            [System.Console]::WriteLine("Received data in ProcessData function:")
            [System.Console]::WriteLine("Variable 1: " + var1)
            [System.Console]::WriteLine("Variable 2: " + var2)
            [System.Console]::WriteLine("Variable 3: " + var3)
            # Perform processing here
            # You can access var1, var2, and var3 in your processing logic
Add-Type -Path $dllPath -Verbose
# Define your data variables
$variable1 = "Data1"
$variable2 = "Data2"
$variable3 = "Data3"
# Call the ProcessData function in the DLL with your data
[MyNamespace.MyDLLClass]::ProcessData($variable1, $variable2, $variable3)
Parents Reply Children
