I'm having an issue with a Pre hook I've written for AAHOOK_EXEC_MENU_COMMAND. Specifically, I'm hooking on a native PW command (command id of IDMD_Redline). The hook works, but has the undesired effect of throwing a blank information dialog when the hook returns AAHOOK_ERROR (you hear the windows error chime, the information button shows in PWE bottom right, and clicking it shows a completely blank dialog titled "Information").
I built a clean version of the DLL with no functions other than the hook, thinking maybe another custom module was to blame, but the problem still persists. I've checked the Last error, and it is always 0. I've tried removing last errors, and still same problem. I have also tried using an Action hook and get the same result. Setting *pResult = TRUE didn't help either. At this point, I'm stumped.
Below is a simplified version built for testing that should demonstrate the problem. We're on PW V8i.
LONG AAAPIHOOK HookMenuCommand_Pre ( LONG hookId, // i Hook Identifier LONG hookType, // i Hook Function Type AAPARAM aParam1, // i Parameter for Hook Function AAPARAM aParam2, // i Parameter for Hook Function AARESULT* pResult // o Return code of the hook function ) { AFX_MANAGE_STATE(AfxGetStaticModuleState()); TRACE (L"\nHookMenuCommand_Pre called...");
switch(aParam2) { case AAOPER_EXEC_MENUCMD: TRACE (L"AAOPER_EXEC_MENUCMD...\n"); break;
default: return AAHOOK_SUCCESS; }
HDOCCMDPARAM hDocParam; LPAADOC_ITEM lpDocItem;
#pragma warning( push ) #pragma warning( disable : 4312 ) LPAACMDPARAM pParam = (LPAACMDPARAM)aParam1; #pragma warning( pop )
if (aParam2==AAOPER_EXEC_MENUCMD) {
if (pParam->lCommandId == IDMD_REDLINE) { hDocParam = *((HDOCCMDPARAM*)pParam->lpParam); lpDocItem = (LPAADOC_ITEM)aaApi_GetDocCmdParamElements(AADOCCMDPT_DOCUMENT1, hDocParam);
if (lpDocItem) { if(AfxMessageBox(L"Redline command intercepted.\n\nContinue?", MB_OKCANCEL)!=IDOK) { return AAHOOK_ERROR; } else return AAHOOK_SUCCESS; } } }
TRACE (L"HookMenuCommand_Pre() finished...\n"); return AAHOOK_SUCCESS; }
JG, do you get the OK / Cancel dialog box just before it errors? It seems if you hit Cancel the code quits with AAHOOK_ERROR.
<QUOTE>
</QUOTE>
DeanLyon:JG, do you get the OK / Cancel dialog box just before it errors? It seems if you hit Cancel the code quits with AAHOOK_ERROR.
Yes I get the popup dialog,which is what I want. I am trying to intercept the Redline command and only allow it in certain cases, based on some workflow stuff (left all that stuff out for testing). Basically what I want is the ability to cancel the command by clicking the Cancel button in the popup dialog
For clarification, I get a blank Information dialog AFTER I click Cancel on my custom dialog. See the attached jpg to see what it looks like.
Yaroslav Lobachevski:Jeff, you tell PW that an error has occured, but you do not set the error code. That is why the dialog is blank. In order to eat the command you should return AAHOOK_SUCCESS, to process the command - AAHOOK_CALL_DEFAULT.
I've written several other Pre hooks that can return AAHOOK_ERROR, which is used as a means to prevent the action from executing, and I've never had to set/unset error codes before, and they don't give me a blank dialog afterward.
Is this a requirement of AAHOOK_EXEC_MENU_COMMAND? if that is what is required, how would you go about this? What we are trying to do is get a confirmation from a user that they really want to run the Redline command under certain circumstances (the processing of those circumstances I've left out for simplicity here), and if they click Cancel, that gives them the way out of the command. Once they click Cancel, that should be the end of it; the command won't run and no other dialogs should appear.
Please note that I post here on a voluntary basis and am not a Bentley employee.
The point is when you return AAHOOK_ERROR in pre or action hook the API function returns failure code. Try it yourself, hook some function, call it and return AAHOOK_ERROR. In menu command executor case there is a handler, which checks if the command was successful. If not it shows the error dialog. However there is no error set. That why it is blank. I don't think it is a bug, because if a function failed without no reason there is something wrong about it.
If your case I would rewrite action hook and return AAHOOK_SUCCESS to suppress the command, but AAHOOK_CALL_NEXT_IN_CHAIN to allow it. Of course you will get post hook even if the command was suppressed, but the function will return success code. You can read more about hooks in SDK ProjectWise Developer's Guide.
