Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
Developers and Programming
ProjectWise Programming
Cancel
ProjectWise Programming Forum
PW VBA
Sign In
Replies
1 reply
Subscribers
11 subscribers
Views
Users
0 members are here
PW VBA
eng_ac
over 13 years ago
How can I customize PW (VBA or Macros) via code internally? Thanks
Offline
Dean Lyon
Mon, May 3 2010 3:02 PM
The only way to customize ProjectWise is to use the ProjectWise API to create a .DLL file. The .DLL file can then be run from PW by a registry entry which expects the .DLL to register hooks, or you can use a .MRR file to load the .DLL when a menu item is selected. There are examples of both of these with the API when you install it. Most of the examples are in C++. I believe that someone on this board posted some help with using Visual Basic with the API.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Cancel
