paper size property in IPLOT Organizer SDK
I am writing an application that will use the IPLOT Organizer SDK to create an ips file to print a PDF with Enable Dynamic Plots checked so that a dot patterned PDF is the output. If I do this by running the application, I would normally go into the properties of the documents and set the paper size option to "Choose paper size by document size" because the original PDF may have pages of multiple sizes. In looking at the properties option in the SDK all I see for paper size is to pick a form name.Can anyone tell me how I would implement the by document size option using the functions in the SDK?
Stephanie
