ProjectWise Integration Module for AutoCad & Civil 3D 2018 Released
ProjectWise Integration Module for AutoCad/C3D 2018 - Released for:
  • Version: 10.00.02.526
  • ProjectWise Design Integration Explorer 10.00.02.203+
ProjectWise Design Integration improves collaboration within distributed organizations through the use of CONNECTED projects and various new ProjectWise Cloud Services. By taking existing projects and associating them with CONNECTED projects in the cloud, you can leverage new Cloud Services including Project Share, Deliverables Management, and Project Performance Dashboards. Users can go to the Personal Portal from ProjectWise Explorer to take advantage of custom LEARNing paths and software recommendations based on role and skill level.
The ProjectWise Integration Module for AutoCad/C3D download contains the installation package needed to integrate AutoCad and Civil 3D 2018 with ProjectWise Design Integration explorer.
The ProjectWise Integration Module for AutoCad/C3D provides the following capabilities:
With this release, we are adding Support for the 2018 version. This version represents a file format change to DWG which necessitated the need to add RealDWG 2018 Libraries to PWDI and Microstation. This add-on module is a port of the robust integration capabilities of previous versions as well as the following major items:
AutoCad
  • Port integration to 2018
  • Title blocks attributes bug fix
  • Real DWG 2018 Support
  • Xref improvements
  • Installer improvements
Civil 3D
  • Improve performance of Data Shortcut Project File.
  • Support Corridor Data Shortcuts
  • Data shortcut Bug fixes
  • Improved support for "Read Only"
  • Prospector Pallete Bug Fixes
  • Improved support for the "dsfolderrepair" command
Notes:
  • No additional license beyond a ProjectWise explorer is required.
Get quick answers in Bentley Communities
  • Search for solutions to issues you are having with Bentley products.
  • Post questions to product community forums.
  • Get information, tips, and advice relating to Bentley software.
Please visit the Bentley ProjectWise You tube channel for the latest product videos
