ProjectWise Integration Module for Revit 2018 - Released for:
Version: 10.00.02.320
ProjectWise Design Integration Explorer 10.00.02.320+
ProjectWise Design Integration improves collaboration within distributed organizations through the use of CONNECTED projects and various new ProjectWise Cloud Services. By taking existing projects and associating them with CONNECTED projects in the cloud, you can leverage new Cloud Services including Project Sharing, Deliverables Management, and Project Performance Dashboards. Users can go to the Personal Portal from ProjectWise Explorer to take advantage of custom LEARNing paths and software recommendations based on role and skill level.
The ProjectWise Integration Module for Revit download contains the installation package needed to integrate 64-bit Revit with ProjectWise Design Integration 10.00.02.320+
The ProjectWise Advanced Integration Module for Revit provides the following capabilities: With this release, we are adding Support for the Advanced Integration with Revit 2018. This add-on module is a port of the robust integration capabilities of previous versions as well as the following major items: • This integration module delivers ProjectWise integration support for Advanced Autodesk Revit 2018 Application integration • Users who install this integration module can expect the same level of ProjectWise integration with Revit 2018 as they had with Revit 2016 and 2017. • Technical Preview of the imbedded ProjectWise Issues Resolution Service. Notes: • No additional license beyond a ProjectWise Design Integration Visa is required.
Learn Content:
Get quick answers in Bentley Communities
Get information, tips, and advice relating to Bentley software.
Please visit the Bentley ProjectWise You tube channel for the latest product videos
Can you send a link to this download as I can't find it on
Sorry in the download area ...at least all the eplorer clients don't seem to include 2018
Hi Greg,
The Revit 2018 Advanced Integration module is a separate add-in module for ProjectWise Design integration Update 2.3. It will be merged into the PW Explorer installer in the next release. To find it in the downloads page, remove the default filter on that page for CONNECT Edition and search for "ProjectWise Explorer Client." The Revit AI module will be second in the list of results.
Phil
There seems to be some issues around this integration. My Colleagues with Revit version 2018.2 are having issues - the PW integration doesn't seem to work - when they press open it just goes to local drive - we are all using PW Connect 2.3.
I don't have 2018.2, (I have the standard 2018 version) but have other issues including only one data source available.
I've noticed there is a Revit 2018.3 available now, it's whether I take the gamble & install & see if it works.
It's just very difficult currently, we are trying to run a project using Revit 2018 & PW from different locations & companies and we just can't get it working. It'd be great if someone has already solved these issues who could help out.
Hi Matthew, have you take a look at the documentation on how to setup the PWDI Revit Project? Here is a link with the instructions.
