With the this release we are Building upon the initial releases and expanding the capabilities of ProjectWise Design Integration.What’s New in ProjectWise Design Integration Update 3.2, version 10.00.03.271:
This version now supports
Where to find the implementation guide?
usually you have to install the server to get to it (which drives me crazy) but I installed integration server and don't see it. installed admin to see if it was there and didn't see it there either. not on docs.bentley.com either.
There was an implementation guide v3.2 posted on the Files section. But it was published in June 2019. Is it the implementation guide for the 3.2 refresh? I am also concerned about the installation method of this version. It looks like a black box and will be difficult for trouble-shooting. You can remove some modules by selecting "Modify" of the product through Control Panel. Is it a best practice to main such a complex system? I am not sure and it drive my crazy, too.
Ah good catch, this is the implementation guide from the 262 release. I'm guessing it's identical to the 271 release as i think (Phil correct me if i'm wrong) there are only bug fixes between 262 and 271 as 262 was pulled early.
https://communities.bentley.com/products/projectwise/content_management/m/mediagallery/273848
I've updated the link Kevin shared with the latest Implementation guide.
