Single Sign-on
Our Company is starting to implement PW CONNECT (10.0.2.320) on Windows 10 laptops. Mind you: NOT web server nor cloud services. Also it is just the clients that get updated, Serverside is v8i RU2.
We encounter a ProjectWise "challenge" regarding authentication from the ProjectWise client to the back-end.
Currently, our ProjectWise client (v8i) has a single sing-on experience based on domain authentication. We are working on a new workspace concept which is a Azure AD joined device only, and uses modern authentication. So no domain authentication at all.
Is it possible for the ProjectWise client to authenticate to the back-end based on OAuth2 (modern authentication), so that we can achieve single sign-on?
If so, what would be necessary to achieve this?
If not, is there any other way to use single sign for ProjectWise without domain authentication?
Any help is welcome!
Thanks for reading,
Yvonne
