Does this SQL statement need to be changed now that a "Project" is now a "Work Area"? EXEC sp_project_path $VAULT$
Is this a stored procedure you created yourself or something Bentley has in the database already? I believe during upgrades ProjectWise moves custom stored procedures, you'll probably need to recreate it.
The SQL statement was in an attribute that I used on an interface. The attribute shows the folder path that the file is in. I'm guessing I need to find out what the new syntax should be now that's called a "Work Area" and not a "Project"
SQL statement on attribute would not need any change provided stored procedure 'sp_project_path' works, this SP looks like a custom one, better check what is it executing.
The name change to work area did not change the variables. It was primarily a display name change versus a change at the code level.
This is the code I'm using, it's not working in my new datasource. I exported the AAM file and imported into the new datasource. Is there something else I need to do to make this work? I looked in the new SQL database and it didn't seem to have the same structure as my old one.
USE [pw1]
GO
/****** Object: StoredProcedure [dbo].[sp_project_path] Script Date: 8/7/2018 10:48:26 AM ******/
SET ANSI_NULLS ON
SET QUOTED_IDENTIFIER ON
ALTER PROCEDURE [dbo].[sp_project_path]
@folder int -- '$VAULT$'
AS
DECLARE @foldername1 nvarchar(100), @foldername2 nvarchar(100), @foldername3 nvarchar(100)
WHILE @folder > 0
BEGIN
SET @foldername3 = (SELECT o_projectname FROM dbo.dms_proj WHERE o_projectno = @folder)
SET @foldername2 =
(SELECT o_parentno FROM dbo.dms_proj WHERE o_projectno = @folder))
SET @foldername1 =
(SELECT o_parentno FROM dbo.dms_proj WHERE o_projectno = @folder)))
SET @folder = (SELECT o_parentno FROM dbo.dms_proj WHERE o_projectno = @folder)
IF (SELECT o_parentno FROM dbo.dms_proj WHERE o_projectno =
(SELECT o_parentno FROM dbo.dms_proj WHERE o_projectno = @folder)) = 0
BREAK
ELSE
CONTINUE
END
SELECT @foldername1 + '\' + @foldername2 + '\' + @foldername3
