PW Explorer crashes when only changing case on rename
I'm wondering if anyone else can reproduce this error in ProjectWise Explorer.
If you try to rename a file but only change some character's case on the name such as from uppercase to lowercase, PW will become unresponsive.
It may eventually give the error Last Error `55502 Invalid socket.The connection to the remote host is broken.
I always have to End Task on PW and restart it.
Note that if you actually change the filename such as add a 2 at the end, then it works fine and the case change will take affect also.
We can reproduce this error every time and on different PCs.
PW Explorer 10.00.03.262
