WSG How to obtain an auth token?
Quote from the doc:
"For Bentley Web Services Gateway running in the Bentley CONNECT environment, all requests must have a Token header."
What is the auth endpoint and request details to obtain a valid token for an existing IMS user?
Can someone give an example. Curl or other way to communicate the usage.
Thank you
Olivier
