ProjectWise drive 0x80070643 fatal error during installation
Getting 0x80070643 fatal error during installation when I'm trying to install the ProjectWise Drive.
ProjectWiseDrive2021.3.283.0 downloaded from ProjectWise Web.
Widows 10 21H1
Screenshot below and log file attached.
Please help!
ProjectWise_Drive_20210909132221.log
[36F0:10B0][2021-09-09T13:22:21]i001: Burn v3.11.2.4516, Windows v10.0 (Build 19043: Service Pack 0), path: C:\Users\JIANG~1.AIZ\AppData\Local\Temp\{557E1133-3A6B-47BC-8AB7-A8293583A03B}\.cr\ProjectWiseDrive2021.3.283.0.exe
[36F0:10B0][2021-09-09T13:22:21]i000: Initializing version variable 'BundledVCRedistVersion' to value '14.28.29913'
[36F0:10B0][2021-09-09T13:22:21]i009: Command Line: '-burn.clean.room=C:\Users\Jiang.Aizezi\Downloads\ProjectWiseDrive2021.3.283.0.exe -burn.filehandle.attached=556 -burn.filehandle.self=564'
[36F0:10B0][2021-09-09T13:22:21]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Jiang.Aizezi\Downloads\ProjectWiseDrive2021.3.283.0.exe'
[36F0:10B0][2021-09-09T13:22:21]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Jiang.Aizezi\Downloads\'
[36F0:10B0][2021-09-09T13:22:21]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\ProjectWise_Drive_20210909132221.log'
[36F0:10B0][2021-09-09T13:22:21]i000: Setting string variable 'WixBundleName' to value 'ProjectWise Drive'
[36F0:10B0][2021-09-09T13:22:21]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Inc.'
[36F0:1D3C][2021-09-09T13:22:21]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[36F0:1D3C][2021-09-09T13:22:21]i000: Setting version variable 'WixBundleFileVersion' to value '2021.3.283.0'
[36F0:10B0][2021-09-09T13:22:21]i100: Detect begin, 4 packages
[36F0:10B0][2021-09-09T13:22:21]i000: Setting string variable 'CBNumber' to value '19043'
[36F0:10B0][2021-09-09T13:22:21]i052: Condition 'VersionNT64' evaluates to true.
[36F0:10B0][2021-09-09T13:22:21]i000: Setting version variable 'VCRedist2019x64' to value '14.29.30133.0'
[36F0:10B0][2021-09-09T13:22:21]i052: Condition 'VCRedist2019x64 AND VCRedist2019x64 > BundledVCRedistVersion' evaluates to true.
[36F0:10B0][2021-09-09T13:22:21]i101: Detected package: VC_redist.x64.exe, state: Present, cached: None
[36F0:10B0][2021-09-09T13:22:21]i101: Detected package: ProjectWiseDriveInstaller.CurrentUser.msi, state: Absent, cached: None
[36F0:10B0][2021-09-09T13:22:21]i101: Detected package: DependenciesPackage.msi, state: Absent, cached: None
[36F0:10B0][2021-09-09T13:22:21]i101: Detected package: ProjectWiseDriveInstaller.msi, state: Absent, cached: None
[36F0:10B0][2021-09-09T13:22:21]i052: Condition 'CBNumber > 17762' evaluates to true.
[36F0:10B0][2021-09-09T13:22:21]i199: Detect complete, result: 0x0
[36F0:1D3C][2021-09-09T13:22:23]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[36F0:10B0][2021-09-09T13:22:23]i200: Plan begin, 4 packages, action: Install
[36F0:10B0][2021-09-09T13:22:23]w321: Skipping dependency registration on package with no dependency providers: VC_redist.x64.exe
[36F0:10B0][2021-09-09T13:22:23]i000: Setting string variable 'WixBundleRollbackLog_ProjectWiseDriveInstaller.CurrentUser.msi' to value 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\ProjectWise_Drive_20210909132221_000_ProjectWiseDriveInstaller.CurrentUser.msi_rollback.log'
[36F0:10B0][2021-09-09T13:22:23]i000: Setting string variable 'WixBundleLog_ProjectWiseDriveInstaller.CurrentUser.msi' to value 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\ProjectWise_Drive_20210909132221_000_ProjectWiseDriveInstaller.CurrentUser.msi.log'
[36F0:10B0][2021-09-09T13:22:23]w322: Skipping cross-scope dependency registration on package: DependenciesPackage.msi, bundle scope: PerUser, package scope: PerMachine
[36F0:10B0][2021-09-09T13:22:23]i000: Setting string variable 'WixBundleRollbackLog_DependenciesPackage.msi' to value 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\ProjectWise_Drive_20210909132221_001_DependenciesPackage.msi_rollback.log'
[36F0:10B0][2021-09-09T13:22:23]i000: Setting string variable 'WixBundleLog_DependenciesPackage.msi' to value 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\ProjectWise_Drive_20210909132221_001_DependenciesPackage.msi.log'
[36F0:10B0][2021-09-09T13:22:23]w322: Skipping cross-scope dependency registration on package: ProjectWiseDriveInstaller.msi, bundle scope: PerUser, package scope: PerMachine
[36F0:10B0][2021-09-09T13:22:23]i000: Setting string variable 'WixBundleRollbackLog_ProjectWiseDriveInstaller.msi' to value 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\ProjectWise_Drive_20210909132221_002_ProjectWiseDriveInstaller.msi_rollback.log'
[36F0:10B0][2021-09-09T13:22:23]i000: Setting string variable 'WixBundleLog_ProjectWiseDriveInstaller.msi' to value 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\ProjectWise_Drive_20210909132221_002_ProjectWiseDriveInstaller.msi.log'
[36F0:10B0][2021-09-09T13:22:23]i201: Planned package: VC_redist.x64.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[36F0:10B0][2021-09-09T13:22:23]i201: Planned package: ProjectWiseDriveInstaller.CurrentUser.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[36F0:10B0][2021-09-09T13:22:23]i201: Planned package: DependenciesPackage.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: None
[36F0:10B0][2021-09-09T13:22:23]i201: Planned package: ProjectWiseDriveInstaller.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: None
[36F0:10B0][2021-09-09T13:22:23]i299: Plan complete, result: 0x0
[36F0:10B0][2021-09-09T13:22:23]i300: Apply begin
[36F0:10B0][2021-09-09T13:22:23]i010: Launching elevated engine process.
[36F0:10B0][2021-09-09T13:22:25]i011: Launched elevated engine process.
[36F0:10B0][2021-09-09T13:22:25]i012: Connected to elevated engine.
[345C:4850][2021-09-09T13:22:25]i358: Pausing automatic updates.
[345C:4850][2021-09-09T13:22:25]i359: Paused automatic updates.
[345C:4850][2021-09-09T13:22:25]i360: Creating a system restore point.
[345C:4850][2021-09-09T13:22:25]i361: Created a system restore point.
[36F0:10B0][2021-09-09T13:22:25]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{24370ae3-ceec-435f-8107-b3bdd19694a4}, options: 0x7, disable resume: No
[36F0:10B0][2021-09-09T13:22:25]i000: Caching bundle from: 'C:\Users\JIANG~1.AIZ\AppData\Local\Temp\{C8955D72-AD2B-4E05-BEFE-B1FCDF8D6534}\.be\ProjectWiseDrive2021.3.283.0.exe' to: 'C:\Users\Jiang.Aizezi\AppData\Local\Package Cache\{24370ae3-ceec-435f-8107-b3bdd19694a4}\ProjectWiseDrive2021.3.283.0.exe'
[36F0:10B0][2021-09-09T13:22:25]i320: Registering bundle dependency provider: {24370ae3-ceec-435f-8107-b3bdd19694a4}, version: 2021.3.283.0
[36F0:10B0][2021-09-09T13:22:25]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{24370ae3-ceec-435f-8107-b3bdd19694a4}, resume: Active, restart initiated: No, disable resume: No
[36F0:2FF8][2021-09-09T13:22:25]i305: Verified acquired payload: ProjectWiseDriveInstaller.CurrentUser.msi at path: C:\Users\Jiang.Aizezi\AppData\Local\Package Cache\.unverified\ProjectWiseDriveInstaller.CurrentUser.msi, moving to: C:\Users\Jiang.Aizezi\AppData\Local\Package Cache\{51448209-E34E-452D-BEB7-391BA910FE08}v21.3.283.0\ProjectWiseDriveInstaller.CurrentUser.msi.
[345C:0E94][2021-09-09T13:22:25]i305: Verified acquired payload: DependenciesPackage.msi at path: C:\ProgramData\Package Cache\.unverified\DependenciesPackage.msi, moving to: C:\ProgramData\Package Cache\{A66D9F94-09DE-4EB1-8A1B-E7A2A53C0D5E}v21.3.283.0\DependenciesPackage.msi.
[345C:0E94][2021-09-09T13:22:26]i305: Verified acquired payload: ProjectWiseDriveInstaller.msi at path: C:\ProgramData\Package Cache\.unverified\ProjectWiseDriveInstaller.msi, moving to: C:\ProgramData\Package Cache\{BF8C1258-5A6A-4EEC-B1AD-197737FED7CE}v21.3.283.0\ProjectWiseDriveInstaller.msi.
[36F0:10B0][2021-09-09T13:22:26]i323: Registering package dependency provider: {51448209-E34E-452D-BEB7-391BA910FE08}, version: 21.3.283.0, package: ProjectWiseDriveInstaller.CurrentUser.msi
[36F0:10B0][2021-09-09T13:22:26]i301: Applying execute package: ProjectWiseDriveInstaller.CurrentUser.msi, action: Install, path: C:\Users\Jiang.Aizezi\AppData\Local\Package Cache\{51448209-E34E-452D-BEB7-391BA910FE08}v21.3.283.0\ProjectWiseDriveInstaller.CurrentUser.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[36F0:10B0][2021-09-09T13:22:26]i319: Applied execute package: ProjectWiseDriveInstaller.CurrentUser.msi, result: 0x0, restart: None
[36F0:10B0][2021-09-09T13:22:26]i325: Registering dependency: {24370ae3-ceec-435f-8107-b3bdd19694a4} on package provider: {51448209-E34E-452D-BEB7-391BA910FE08}, package: ProjectWiseDriveInstaller.CurrentUser.msi
[345C:4850][2021-09-09T13:22:26]i301: Applying execute package: DependenciesPackage.msi, action: Install, path: C:\ProgramData\Package Cache\{A66D9F94-09DE-4EB1-8A1B-E7A2A53C0D5E}v21.3.283.0\DependenciesPackage.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[36F0:10B0][2021-09-09T13:22:26]i319: Applied execute package: DependenciesPackage.msi, result: 0x0, restart: None
[345C:4850][2021-09-09T13:22:26]i301: Applying execute package: ProjectWiseDriveInstaller.msi, action: Install, path: C:\ProgramData\Package Cache\{BF8C1258-5A6A-4EEC-B1AD-197737FED7CE}v21.3.283.0\ProjectWiseDriveInstaller.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[345C:4850][2021-09-09T13:22:28]e000: Error 0x80070643: Failed to install MSI package.
[345C:4850][2021-09-09T13:22:28]e000: Error 0x80070643: Failed to execute MSI package.
[36F0:10B0][2021-09-09T13:22:28]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[36F0:10B0][2021-09-09T13:22:28]i319: Applied execute package: ProjectWiseDriveInstaller.msi, result: 0x80070643, restart: None
[36F0:10B0][2021-09-09T13:22:28]e000: Error 0x80070643: Failed to execute MSI package.
[345C:4850][2021-09-09T13:22:28]i318: Skipped rollback of package: ProjectWiseDriveInstaller.msi, action: Uninstall, already: Absent
[36F0:10B0][2021-09-09T13:22:28]i319: Applied rollback package: ProjectWiseDriveInstaller.msi, result: 0x0, restart: None
[345C:4850][2021-09-09T13:22:28]i351: Removing cached package: ProjectWiseDriveInstaller.msi, from path: C:\ProgramData\Package Cache\{BF8C1258-5A6A-4EEC-B1AD-197737FED7CE}v21.3.283.0\
[345C:4850][2021-09-09T13:22:28]i301: Applying rollback package: DependenciesPackage.msi, action: Uninstall, path: (null), arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[36F0:10B0][2021-09-09T13:22:29]i319: Applied rollback package: DependenciesPackage.msi, result: 0x0, restart: None
[345C:4850][2021-09-09T13:22:29]i351: Removing cached package: DependenciesPackage.msi, from path: C:\ProgramData\Package Cache\{A66D9F94-09DE-4EB1-8A1B-E7A2A53C0D5E}v21.3.283.0\
[36F0:10B0][2021-09-09T13:22:29]i326: Removed dependency: {24370ae3-ceec-435f-8107-b3bdd19694a4} on package provider: {51448209-E34E-452D-BEB7-391BA910FE08}, package ProjectWiseDriveInstaller.CurrentUser.msi
[36F0:10B0][2021-09-09T13:22:29]i301: Applying rollback package: ProjectWiseDriveInstaller.CurrentUser.msi, action: Uninstall, path: (null), arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[36F0:10B0][2021-09-09T13:22:30]i319: Applied rollback package: ProjectWiseDriveInstaller.CurrentUser.msi, result: 0x0, restart: None
[36F0:10B0][2021-09-09T13:22:30]i329: Removed package dependency provider: {51448209-E34E-452D-BEB7-391BA910FE08}, package: ProjectWiseDriveInstaller.CurrentUser.msi
[36F0:10B0][2021-09-09T13:22:30]i351: Removing cached package: ProjectWiseDriveInstaller.CurrentUser.msi, from path: C:\Users\Jiang.Aizezi\AppData\Local\Package Cache\{51448209-E34E-452D-BEB7-391BA910FE08}v21.3.283.0\
[36F0:10B0][2021-09-09T13:22:30]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{24370ae3-ceec-435f-8107-b3bdd19694a4}, resume: None, restart: None, disable resume: No
[36F0:10B0][2021-09-09T13:22:30]i330: Removed bundle dependency provider: {24370ae3-ceec-435f-8107-b3bdd19694a4}
[36F0:10B0][2021-09-09T13:22:30]i352: Removing cached bundle: {24370ae3-ceec-435f-8107-b3bdd19694a4}, from path: C:\Users\Jiang.Aizezi\AppData\Local\Package Cache\{24370ae3-ceec-435f-8107-b3bdd19694a4}\
[36F0:10B0][2021-09-09T13:22:30]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{24370ae3-ceec-435f-8107-b3bdd19694a4}, resume: None, restart initiated: No, disable resume: No
[36F0:10B0][2021-09-09T13:22:30]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart:  No
