Renditions and Document Codes
Now I assume the answer is no, but has anyone ever come up with a method of getting a rendition to generate a document code that matches the source document code other than an additional attribute that you nominate?
Example - Source Doc Code 111-XXX-001 (Additional attribute: NATIVE) to generate Target Doc Code 111-XXX-001 (Additional attribute: PUBLISHED) in the same (or different for that matter) environment.
Cheers
Matt
