ProjectWise Drive - Bulk add files?
I've finally got a chance to start experimenting with ProjectWise Drive and see some interesting possibilities here.
One thing I did was copy in about 5,000 files into one of my Drives. I can see the folders got created in ProjectWise, but I have to right-click files and select Add To Drive. I can select multiples, but when I do I have to then individually approve every filename being added. Is there a way to automatically have the files added as well, or at least right-click a folder and "Import all files".
  • Kevin. Have a chat with Development Team. I'm told new features are coming. That enable dynamic creation and edit
    Chris
    AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
    Principal Engineer – Digital
    OpenRoads Designer 10.10 | Microstation CE 10.16 | ProjectWise CE 3.4
  • Hey Kevin,
    Are you needing to use a Document Code for these Files or simply emulate the "simple" drag-n-drop action of ProjectWise Explorer? If the latter, there is a checkbox at the bottom of the Create Document Wizard that can forgo prompts for each File.
    Hope that this helps.
    ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
    ProjectWise Drive, Version 2021.3.283.0
    OpenRoads Designer CONNECT Edition, Version 10.09.00.091
    Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
