Missing something easy in getting PowerShell for PW going...
Ok, this is a going to be an easy for someone to answer...
I am new to the PowerShell ProjectWise concept and trying hard to learn to get needed functionality.
But I cannot get Powershell to recognize that the Modules are installed and the functions exposed...
Supposedly I have the PWPS_DAB Module installed.
Tried the standard "Windows PowerShell ISE" and got the message that the architecture was wrong...
Import-Module -Name PWPS
Import-Module -Name PWPS_DAB -DisableNameChecking
Import-Module : The specified module 'PWPS' was not loaded because no valid module file was found in any module directory.
At line:1 char:1
+ Import-Module -Name PWPS
+ CategoryInfo : ResourceUnavailable: (PWPS:String) [Import-Module], FileNotFoundException
+ FullyQualifiedErrorId : Modules_ModuleNotFound,Microsoft.PowerShell.Commands.ImportModuleCommand
Import-Module : The current processor architecture is: Amd64. The module 'C:\Program
Files\WindowsPowerShell\Modules\PWPS_DAB\1.3.12.0\PWPS_DAB.psd1' requires the following architecture: X86.
At line:3 char:1
+ Import-Module -Name PWPS_DAB -DisableNameChecking
+ CategoryInfo : ResourceUnavailable: (C:\Program File...0\PWPS_DAB.psd1:String) [Import-Module], InvalidOperationExce
ption
+ FullyQualifiedErrorId : Modules_InvalidProcessorArchitecture,Microsoft.PowerShell.Commands.ImportModuleCommand
So then I tried the "Windows PowerShell ISE (x86)" and got the message that "open-pwconnection" is not recognized...
$result = open-pwconnection "any"
The term 'open-pwconnection' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was
included, verify that the path is correct and try again.At line:1 char:11
+ $result = open-pwconnection "PW Dev"
+ CategoryInfo : ObjectNotFound: (open-pwconnection:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Neither ISE session will show the PW Module Commands in the "Command" Add-on.
What is the obvious thing that I am missing?
