Version 1.5.10.0 of PWPS_DAB just posted to the PowerShell Gallery
We just posted version 1.5.10.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install: Run an Admin session of 32-bit PowerShell v5 and use the cmdlet Update-Module PWPS_DAB (if you already have the module) or Install-Module PWPS_DAB (for a new install). One can run Uninstall-Module PWPS_DAB first just to clean up old installs. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available via the BE Communities site ( communities.bentley.com/.../projectwise-powershell-extensions-forum ).
