Version 1.10.1.0 of PWPS_DAB just posted to the PowerShell Gallery
We just posted version 1.10.1.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install: Run an Admin session of 32-bit PowerShell v5 and use the cmdlet Update-Module PWPS_DAB (if you already have the module) or Install-Module PWPS_DAB (for a new install). One can run Uninstall-Module PWPS_DAB first just to clean up old installs. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available via the BE Communities site ( communities.bentley.com/.../projectwise-powershell-extensions-forum ).
  • 2019-03-26 Version 1.10.1.0
    Added cmdlets
    • Set-PWDocumentMIMEType
      • Update document MIME Type.
    • Set-PWDocumentVersion
      • Set the Document Version string on active documents.
    Changed cmdlets
    • New-PWDMTransmittal
      • improved support for non-federated domain logins
