Version 1.10.2.0 of PWPS_DAB just posted to the PowerShell Gallery
We just posted version 1.10.2.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install: Run an Admin session of 32-bit PowerShell v5 and use the cmdlet Update-Module PWPS_DAB (if you already have the module) or Install-Module PWPS_DAB (for a new install). One can run Uninstall-Module PWPS_DAB first just to clean up old installs. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available via the BE Communities site ( communities.bentley.com/.../projectwise-powershell-extensions-forum ).
  • 2019-04-05 Version 1.10.2.0
    Added cmdlets
    • Get-PWAttributeExchangeRulesUpdateFileConditions
      • Get current settings for attribute exchange.
    • Set-PWAttributeExchangeRulesUpdateFileConditions
      • Change settings for attribute exchange.
    • Disable-PWTitleBlockUpdate
      • Disables the ProjectWise Titleblock update functionality.
    • Import-PWProjectAccessControl
      • Now supports importing the spreadsheet created by Export-PWProjectAccessControl. Both of these bypass the built-in security export/import because of performance and dependence on installed Excel.
    Changed cmdlets
    • CheckIn-PWDocumentOrFree
      • now will import Exported documents if they are in the set of documents passed in.
    • CheckOut-PWDocuments
      • now properly updates CheckOutLocation on returned document object.
    • Import-PWDocumentsBySpreadsheet
      • fixed bug that caused error when ProjectWiseDocumentVersion types were mixed (string and numeric)
    • Export-PWProjectAccessControl
      • changed to bypass built-in security export to improve performance and reliablity
