Version 1.10.3.0 of PWPS_DAB just posted to the PowerShell Gallery
We just posted version 1.10.3.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install: Run an Admin session of 32-bit PowerShell v5 and use the cmdlet Update-Module PWPS_DAB (if you already have the module) or Install-Module PWPS_DAB (for a new install). One can run Uninstall-Module PWPS_DAB first just to clean up old installs. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available via the BE Communities site ( communities.bentley.com/.../projectwise-powershell-extensions-forum ).
  • 2019-04-09 Version 1.10.3.0
    Changed cmdlets
    • Update-PWStorageAreaForProjectTree
      • fixed major bug that would CAUSE FILE LOSS in the case of a user prevented from seeing documents due to ProjectWise Access Control.
      • added -SkipSTorageAreaMatchCheck and changed -DoNotDeleteFromSourceStorage switch to -DeleteFromSourceStorage. Makes deleting the source files a positive choice.
    • Add-PWValidationQRCode
      • added -QRCodeType override parameter and -ForceNativeUnits and -ForceDefaultUnits switches to help with QR Code settings development.
    • Add-PWDocumentFlatSetMember
      • fixed issue with -LockToVersion switch and with input documents.
